ELM327 Support
2026-10-12
VDASH Guide ELM327 Support VDASH support for selected ELM327 diagnostic tools. Overview ELM327 is a supported diagnostic interface in VDASH, but only for basic diagnostics and selected service operations. ELM327 interfaces cannot be used…
VDASH Basics
2026-09-10
VDASH Guide VDASH Basics How to download VDASH, prepare the required hardware, connect your Volvo, and log in for the first time. Overview VDASH is a Windows software tool for Volvo diagnostics, configuration, service functions, software…
Cloning & Replacing a DIM on P2 Volvo Cars in VDASH
2026-08-12
VDASH Guide Cloning & Replacing a DIM on a P2 DIM cloning and replacement in vdash When replacing a DIM (Driver Information Module) on a P2 Volvo, the correct procedure depends on the DIM generation and model year. A DIM can be cloned…
VCM Battery Reset
2026-08-10
VDASH Guide VCM Battery Reset How to reset the Volvo VCM backup battery in VDASH. VCM battery reset Overview The VCM, or Vehicle Connectivity Module, is responsible for several important connectivity and telematics functions in Volvo…
HU850 Retrofit
2026-08-06
VDASH Guide HU850 Retrofit Important checks before replacing HU650 with HU850 audio on a P2. HU850 retrofit requirements Before installing HU850 audio When retrofitting HU850 audio in place of the original HU650, the radio itself is only…
VDASH Support for iCUP / Android Volvo Cars - Diagnostics
2026-07-02
VDASH Guide VDASH Support for iCUP / Android Volvo Cars Diagnostic support information for newer Volvo vehicles equipped with the Android-based iCUP system and VGM security gateway. iCUP / Android Volvo Security iCUP / Android Volvo…
VIDA Purchase Failed: 201 - This car is blocked for software download
2025-05-04
VDASH Guide How to Unblock Your Volvo for Future VIDA Software Updates What to do if an SPA or CMA Volvo becomes blocked for official VIDA software updates after configuration changes. VIDA software update block Why the vehicle gets…
Heated Steering Wheel on a P3 MY2012+
2024-12-14
VDASH Guide Volvo P3 SENSUS Heated Steering Wheel Retrofit How to retrofit a heated steering wheel on compatible Volvo P3 SENSUS cars using VDASH. Heated steering wheel retrofit Applicable vehicles Applicable for: MY 2012+ – S80II, V70III…
The D5T5 Credit and Refund Policy
2021-06-01
When can I request a refund? The D5T5 credit and refund policy You can request a refund for any unused credit within 21 days of purchase. After this period, refunds to your bank account are no longer possible. Please note that any additional…
Volvo P3 Configuration Changes with VDASH
2020-07-11
VDASH Guide Volvo P3 Configuration Changes with VDASH A concise overview of common P3 configuration changes available in VDASH. P3 configuration changes Before you start To change the configuration on P3 cars, you need to decode the CEM…
VDASH in Virtual Environment – VM / VMware / VirtualPC
2020-06-23
VDASH Guide Running VDASH in a Virtual Environment Why VDASH should be installed directly on a native Windows system instead of a virtual machine. Virtual environments are not supported Why VDASH is not allowed in a virtual machine…
Volvo Sensus USA to EU Navigation Conversion
2020-06-23
VDASH Guide Volvo Sensus USA to EU Navigation Conversion How to convert old Volvo Sensus navigation from the USA market to EU – MY2012-2014. Sensus navigation conversion When this applies If you want to convert first-generation Volvo…
SPA / CMA Video in Motion and Pilot Assist
2020-05-21
VDASH Guide SPA / CMA Video in Motion and Pilot Assist How to activate Video in Motion on SPA / CMA models and enable the Pilot Assist function. Function activation What you need To activate this function, you first need to obtain the CEM…
Volvo Market Settings and GPS Activation
2020-05-20
VDASH Guide Volvo Market Settings and GPS Activation A short video guide showing how to change market-related settings, use IHU Engineering Mode, and activate GPS. Market settings and GPS Overview This short video tutorial shows how to…
Engine Remote Start - ERS
2020-05-05
VDASH Guide Volvo P3 Remote Engine Start How to activate engine remote start for Volvo cars with VDASH. Remote engine start Overview Certain P3 Volvo cars can start the engine from the car key, using either a 5-button or 6-button remote,…
Volvo Fuel Heater Activation on P2 with VDASH
2020-03-02
VDASH Guide Volvo Fuel Heater Activation on P2 with VDASH How to activate the fuel heater function in your Volvo using VDASH. Fuel heater activation Available activation options You can activate the fuel heater in two different ways: …
Generic J2534 Device Support
2020-02-27
VDASH Guide Generic J2534 Device Support Expanded hardware compatibility for VDASH diagnostics and ECU programming. Jump to Section Overview SUPER J2534 Alternative HW Warning Supported HW Firmware Summary J2534 Support Overview VDASH…
VDASH PRO Subscription
2020-02-27
VDASH Guide VDASH – PRO Subscription Benefits, price, premium support rules, and when a PRO account makes sense. PRO Subscription Benefits PRO is a one-year subscription with these benefits for you: 25% discount off end-user prices 10%…
Volvo Sensus Connect Navigation Activation with VDASH
2020-01-17
VDASH Guide Volvo Sensus Connect Navigation Activation How to activate built-in navigation in Volvo vehicles with Sensus Connect using VDASH. Navigation activation When navigation can be activated If Sensus Connect is installed in your…
IHU Engineering Mode - Change Region Settings P3
2020-01-17
VDASH Guide IHU Enginnering Mode - Change Region Settings on P3 How to change the infotainment system region after changing the vehicle region configuration in VDASH. Sensus Connect region settings Why this setting matters After you have…
Authorizing a New Computer in VDASH
2019-10-15
VDASH Guide VDASH Computer Authorization How to authorize a new computer when all VDASH hardware slots are already used. Authorize a new computer Why this message appears If you see this notification in VDASH, there has most likely…
TFT Retrofit
2019-05-23
VDASH Guide Volvo P3 TFT DIM Retrofit How to retrofit the newer TFT instrument cluster into supported Volvo P3 cars using VDASH. TFT DIM retrofit Overview All older P3 platforms are equipped with the older version of the instrument…
VDASH - Volvo Diagnostics
2018-11-10
VDASH Professional Volvo diagnostics,configuration and service software Advanced diagnostics, configuration, software update and service tool for personal Volvo vehicles — designed for workshops, professionals and experienced Volvo owners.…
