HU850 Retrofit
Important checks before replacing HU650 with HU850 audio on a P2.
HU850 retrofit requirements
Before installing HU850 audio
When retrofitting HU850 audio in place of the original HU650, the radio itself is only one part of the system. Before replacing the head unit, make sure the rest of the audio setup is already prepared and working correctly.
Configuration note:
There is no actual need for CEM configuration for this retrofit. If the amplifier, wiring, power supply, and HU850 unit are all correct, the HU850 will play normally. The only side effect should be one extra DTC stored in the vehicle.
hu650 hu850 retrofit P2 radio CD
