VDASH
Professional Volvo diagnostics,
configuration and service software
Advanced diagnostics, configuration, software update and service tool for personal Volvo vehicles — designed for workshops, professionals and experienced Volvo owners.
✓ Windows software ✓ Volvo OBD-II diagnostics ✓ DiCE / J2534 compatible ✓ Professional configuration features
Volvo service platform
Diagnostics, coding, software and configuration
Connect through OBD-II to a sophisticated, professional-grade diagnostic and configuration software.
Internet connection required.
Windows 10 or later is strongly recommended.
Professional Volvo control from one software tool.
VDASH is sophisticated software for Windows Vista / 7 / 8 / 10 / 11 operating systems and requires an internet connection to function.
Its primary purpose is the diagnosis and software update of personal Volvo vehicles through the OBD-II connector. VDASH is designed for compatibility with Volvo DiCE based on the J2534 chipset, original DiCE units, proven compatible clones and the SUPER J2534 interface.
Made for Volvo diagnostics
VDASH
A professional software environment for diagnostics, service operations, configuration changes, module cloning, and software updates.
What VDASH helps you do
Diagnostics
Read and delete DTC error codes, view diagnostic information and support service workflows for compatible Volvo vehicles.
Configuration
Adjust supported vehicle configuration options such as region settings, onboard functions, STOP/START and selected comfort features.
Software operations
Perform supported software updates, module operations, cloning and feature activations where available.
Service tools
Reset service intervals, manage service history, print protocols, log data and support everyday workshop operations.
Recommended hardware
Recommended
Volvo DiCE
Original diagnostic interface for VDASH and a proven reliable option for most VDASH operations.
  • Full compatibility with VDASH
  • Based on the J2534 chipset
  • Suitable for diagnostics and software operations
  • Original units are preferred
Best choice
SUPER J2534
Compatible Volvo DiCE replacement and recommended general interface for VDASH use.
SPA / CMA only
Ethernet Adapter VOE
S/FTP cable with RJ45 connector designed for newer Volvo platforms.
PIN decoding via VOE is extremely slow. SUPER J2534 is a better option for decoding.
Use at own risk
Generic J2534
Generic J2534 devices may work for selected VDASH operations, but proper function is not guaranteed.
  • We don't recommend using VXDIAG for ECU programming
  • Compatibility depends on the exact device
  • Some operations may be unstable or unavailable
  • Performance may be slower than DiCE or SUPER J2534
  • Using generic J2534 hardware is at the customer's own risk
Generic J2534 information
SUPER J2534 drivers
Download the correct drivers before connecting the interface.
We strongly recommend using Windows 10 or later. Recent Windows updates have caused compatibility issues with SUPER J2534 drivers, which may prevent the device from functioning correctly.
VDASH features
  • Diagnostics — reading and deleting DTC error codes
  • Resetting service intervals — SRI
  • Changing the language of the onboard computer and radio
  • Engine performance enhancement through engine control unit software updates
  • Vehicle configuration adjustments, including STOP/START, video playback while driving, independent heating, cruise control, onboard computer and USA to EU region changes
  • Removal of the 180 km/h speed limit on MY2021 and newer models, with maximum speed 250 km/h
  • Decoding PIN for CEM and ECM units
  • Adding and removing ignition keys and remote controls
  • Pairing SCL and SCU units
  • Detection of odometer tampering with 99% accuracy for P1, P2, P3, SPA and CMA
  • Copying and cloning electronic modules
  • Injector coding
  • Live data logging
  • Reading READINESS codes
  • Managing vehicle service history
  • Monitoring upcoming technical inspections
  • Printing protocols from service sessions
  • Maintaining a driving logbook in combination with VDD
Supported vehicles
VDASH typically supports all Volvo vehicles from 1999 to the present, excluding the S/V40 first generation from 1996.
P80 S70, V70, C70 from 1999
P1 S40II, V50, C30, C70II
P2 S60, S80, V70II, XC70II, XC90
P3 S60II, S80II, V40II, V40CC, V60, V60CC, V70III, XC60, XC70III
SPA S60III, S60CC, S90II, V60II, V60CC, V90II, V90CC, XC60II, XC90II
CMA C40, XC40
Polestar Polestar 1 and Polestar 2
Software pricing
SPONSORED
Free
for personal use
  • Pay only for individual software features
  • Task price is shown before execution
  • No included support
Important:
Use is at your own risk. Support is charged at €10 excl. VAT / started 10 minutes.
SPONSORED
SMALL
€10
annually, VAT excluded
  • Included free for one year with the SUPER J2534
  • Access to injector coding features
  • Unlimited VINs linked to SMALL account
SMALL Subscription
PRO
€400
  • Sales license / professional account
  • 25% discount on all prices within VDASH
  • 10% discount on products in our e-shop
  • Extended functionality
  • Weekday support from 8:00 to 16:00 CEST
  • 3 hours of support per month
More information about VDASH PRO
PRO Subscription
PRO Verified
Granted
cannot be purchased
  • For long-term collaborators
  • Requires PRO conditions
  • Requires experience with VDASH
  • Requires Volvo vehicle knowledge
This status is granted based on our own discretion and requires thorough D5T5 training.
Verified Dealer
VDASH plans — FLAT CONFIG and FLAT ULTIMATE
Car-bound plans connected to a specific car VIN and your VDASH account.
Pricing and explanation is available here: Subscriptions and Plans | D5T5.com
Frequently asked questions
What operating system does VDASH require?
VDASH is designed for Windows Vista / 7 / 8 / 10 / 11. We strongly recommend using Windows 10 or later.
Do I need an internet connection?
Yes. VDASH requires an internet connection to function.
Which interface should I use?
Volvo DiCE is a proven option, while SUPER J2534 is recommended as the best general replacement for Volvo DiCE. VOE is suitable only for SPA and CMA vehicles. Generic J2534 devices are not guaranteed to function properly and are used at the customer's own risk.
Does VDASH support my Volvo?
VDASH typically supports Volvo vehicles from 1999 to the present, excluding the first-generation S/V40 from 1996. Exact available functions depend on platform, vehicle configuration and supported operations. You can find out more by entering your car's VIN code in our search bar.
Is VDASH free?
VDASH has a SPONSORED option for personal use, where individual software tasks are paid separately. Other subscription options include SMALL, PRO and PRO Verified status.
Which PIN code do I need to access configurations / tuning?
Find out more about PIN codes and how to decode them at
https://d5t5.com/article/volvo_pin_codes_explained and https://d5t5.com/article/volvo-cem-pin-code.
Ready to start with VDASH?
Download the software, connect a compatible interface and access professional Volvo diagnostics, configuration and service functions.
Download VDASH Software
VolvoDiagnosis VDASHsoftware VolvoTuning VehicleDiagnostics CarPerformanceUpgrade VolvoMaintenance VolvoTech VDASHPro CarCareSolutions ProfessionalVolvoService
