Configuration - Change vehicle equipment
Each Volvo is manufactured to pre-specified specifications. Some things can also be done at authorized Volvo dealers - such as: parking sensors, camera, towbar, cruise control, trip computer, etc. These adjustments can also be made via VDASH.
However, some things cannot be done at authorized dealers, and VDASH is the only alternative here. Typically, these include adding heated seats, parking heater, electric tailgate, disabling the STOP-START system, activate video while driving, deactivating the FOUR-C (4C), etc… or what needs to be done in the car. If you are interested in a different configuration than what is shown here, please contact us with a detailed description of what you require.
The explanation of platforms is here: https://d5t5.com/wiki/configuration/article-volvo-platforms
SPA / CMA Platform configuration
- Change of region USA>EU etc. - only SW adjustment
- Service interval change - SW adjustment only
- Video while driving - SW adjustment only
- Navigation activate
- CarPlay / Android auto activation
- removing 180km/h speed limit
P3 - Platform 3 configuration
- TFT retrofit
- Cruise control - buttons on steering wheel + steering wheel wiring
- On-board computer - SW modification only
- Heated seats - climate panel + heating blankets or whole seats
- Ventilated seats - climate panel + ventilated seats
- Premium sound - speakers + amplifier + subwoofer (When having basic sound the wiring and MOST need to be changed because of adding an amplifier under the seat.)
- Timer for parking heater - if the car already has preheating, then only SW adjustment
- Parking heater - parking heater Eberspacher
- Remote activation of parking heater - SW adjustment only (MY2012 + only)
- BLIS - mirrors + cabling + button on climate panel + door modules
- ABL Xenons - HCM unit + headlamps + LSM module + Wiring + Levelling sensors
- Xenon deactivation - H7 headlamps + manual LSM module
- Deactivation of the Four-C chassis - standard shock absorbers + rewire of levelling sensors on the axle
- Deactivation of STOP-START / Drive-E - SW adjustment only
- Video while driving - SW adjustment only (Sensus / Sensus Connect models only)
- Activation of navigation for SENSUS - IHU + cabling + antenna
- Activation of navigation at SENSUS Connect - only SW modification (if the vehicle has preparation)
- Change of region USA> EU etc. - only SW adjustment + exchange of DIM dial
- Rain sensor - sensor + window + handle
- Parking sensors - control unit + wiring + sensors
- Tire size / wheel circumference change - SW adjustment only
- Self-dimming mirror - mirror
- Deactivating dead-lock - only SW adjustment
- Parking camera - camera + cabling + unit
- Maximum speed increase / limiter - SW adjustment only
- Deactivation of neutral control - SW adjustment only
P2 - Platform 2 configuration
- Heated seats - panel buttons + heating blankets or whole seats + SHM modules
- Premium sound - speakers + radio + amplifier
- Parking heater - Webasto parking heater
- Ventilation timer - SW adjustment only
- BLIS - mirrors + cabling + button on climate panel (only from MY05+)
- ABL Xenon Units - HCM + Wiring + Headlamps (MY05+ only) + LSM Module
- Deactivation of the Four-C chassis - standard shock absorbers + rewiring of levelling sensors on the axle
- Activation / deactivation of automatic locking - SW adjustment only
- Alarm deactivation - SW adjustment only
P1 - Platform 1 configuration
- Premium sound - speakers + audio module + optical cables + subwoofer
- Self-dimming mirror - mirror + wiring
Important info:
D5T5 s.r.o. is not responsible for any non-compatible configuration change. If you change anything, what is not compatible with your car due to missing hardware or not supported function in your model year or your car model, you have no "warranty" and D5T5 s.r.o. will not refund money for the change. It is your responsibility to check, that your car is fully compatible with the desired configuration change. Any support from D5T5 s.r.o. may be charged.
