Volvo Fuel Heater Activation on P2 with VDASH
How to activate the fuel heater function in your Volvo using VDASH.
Fuel heater activation
Available activation options
You can activate the fuel heater in two different ways:
- With timer and additional heater - this option displays the timer in the car menu, and the heater will also start automatically when the outside temperature drops to approximately 5 °C.
- With timer only - the fuel heater will operate only when it is started directly using the timer.
Before you begin
Make sure you have the CEM PIN for your vehicle. Connect the car to VDASH and check the CEM PIN status. If this cannot be done, follow this guide: https://d5t5.com/article/volvo-cem-pin-code
Activation steps in VDASH
To activate the fuel heater, follow the steps shown below:
Important: Once the configuration change is complete, lock the vehicle for 5 minutes.
