Readiness Codes & Emissions Testing
A simple explanation of OBD readiness monitors, why they matter during emissions inspections, and how to read them with VDASH.
What Are Readiness Codes?
Readiness codes are part of the vehicle’s onboard diagnostics system, also known as OBD. They show whether the engine control unit has completed its self-checks for emissions-related systems.
They do not directly say whether a vehicle has passed or failed. Instead, they show whether the vehicle has had enough operating time to check important components such as the catalyst, oxygen sensors, EGR system, secondary air system, fuel system, and evaporative emissions system.
Emissions Testing
Why They Matter During Emissions Testing
During an emissions inspection, the testing station may connect diagnostic equipment to the vehicle’s OBD port. The system can read stored fault codes, check the diagnostic connection, and verify readiness monitor status.
If fault codes were recently cleared, many readiness monitors are reset. This means the vehicle may appear to have no active warning light, but still be marked as not ready for inspection because the self-tests have not finished yet.
VDASH Readiness Check
Reading Readiness Codes with VDASH
With VDASH, you can read readiness codes directly from the vehicle and check whether the emissions-related monitors are complete before going to an inspection.
What you need:
This makes VDASH useful not only for diagnostics, configurations, and engine tuning, but also for confirming that the vehicle is ready before an emissions test.
Readiness Values
What Do 0 and 1 Mean?
0 usually means the monitor is complete and ready.
1 usually means the monitor is incomplete, not ready, or there may be a fault in that monitored area.
In many diagnostic tools, readiness is displayed as an eight-position value. Each position represents a different emissions-related system, such as EGR, lambda sensor heating, lambda sensor, secondary air system, fuel tank ventilation, heated catalyst, or catalyst monitoring.
Example:
A readiness value of 00000000 generally means all monitored systems are ready and functional.
A value such as 00000010 means one position contains a 1. In the VAG readiness example, this points to the heated catalyst area, so that monitor should be checked before the emissions inspection.
This is why technicians usually want to see only zeros before an emissions test. If a 1 appears, the vehicle may need more driving time, a completed drive cycle, or further diagnostics.
Why a Vehicle May Not Be Ready
A vehicle may be not ready after the battery was disconnected, fault memory was cleared, repairs were performed, or the vehicle has not yet completed the required drive cycle.
Common requirements before monitors complete:
  • Engine reaches operating temperature
  • Vehicle is driven at steady speed
  • Acceleration and deceleration conditions are met
  • Idle time is completed
  • No active emissions-related faults are present
  • Fuel level and sensor temperatures are within the required range
Some vehicles complete readiness during normal mixed driving. Others may require a manufacturer-specific drive cycle or a guided readiness procedure using diagnostic software.
Key Takeaway
Readiness codes prove that the vehicle’s emissions systems have completed their self-checks. Clearing fault codes shortly before an inspection usually resets readiness, so the vehicle may still fail the diagnostic part of the emissions test. With VDASH, a D5T5 account, and a SUPER J2534, you can read readiness codes before inspection and confirm whether the vehicle is prepared.
