Questions & answers
  • First
  • Previous
  • Next
  • Last
EN
There is no DECODE CEM button when I connect my VC40 to VDASH. What I am doing wrong? Is there a manual for VDASH I can download?
EN
Last May, they said it would be possible to call up the ECM PIN CODE using VDASH in about two months. Is ECU CHIP TUNE possible by now?
EN
Would you tell me how to do optimazation for P3 2.0T (MED17 ecu) ,should get pin code ? And would you tell me where to buy clone Dice ?
EN
I have now read the CEM of my vehicle for several days to get the PIN code. After 8 hours I got a coding of 1.16%. Is there perhaps a way to get the PIN code faster? Or should I maybe use a faster computer? Is it faster with the Dice than with the…
EN
Can you help me go turn off start and stop. Activate navigation. [XC70 2016]
EN
Is there a possibility of manual hardware removal without waiting 30 days?
EN
Have you added support for my TCM 000030759364 when I try to clone I get error message. VDASH is not able to continue, because unit Tcm is not supported yet. [S80 2007]
CS
Našiel som v sekcii Zmena konfiguracie auta možnosť zmeny Buetooth telefonovanie na Bluetooth telefonovanie+ streaming hudby. Je táto zmena len softwarová alebo musí byť menený aj hardware? [XC60 2010]
EN
When I clicked TFT RETROFIT engine was not shut off and no way to cancel the process from the window. Now car won't start...
EN
I was just wondering if there are any possibility to program my car so that it works like the new XC70 where you have automatic DRL's in the fog lamp, or if I need to change the fog lamp from halogen to led to get this working? also I notice when…
CS
Mám S60 2001 125kw benzín, a nefunguje mi dálkové ovládání na řidičovi dveře (ostatní odemkne a zamkne normálně) , vyměnil sem zámek dveří a pořád stejné, musí se to nějak přehrát nebo mám hledat závadu jinde ?
EN
I bought V60 PHEV twin-engine newest MY2020 late. I would like to enable Video In Motion. However, vdash2 could not read CEM module, then I could not decode KEY code. Vdash2 support MY2020 model ?
EN
Could you refund my Credits? I was making clone about bcm and needs Credit so i transfered. After that software says that bcm cloning is not possible. So now I have useless Credits, and i don't need cloning anymore because i swapped Electronic…
CS
Chtěl bych do mého vozu (XC90 P2 2005) instalovat rádio z XC90 2008 je to možné?
EN
I reset my CEM because I wanted to make a configuration change and could not remember what the original setting was. I then went back in to reinstall the changes I had on there previously apart from the setting I was looking to adjust. I tried to…
  • First
  • Previous
  • Next
  • Last
General Terms and Conditions | Terms and Conditions | Privacy policy | v2.109.2 b20260902
