TFT Retrofit Wires – Connector Repair Terminals for New TFT Cluster Installation (30656697)
Genuine Volvo repair terminals (flat female contacts), needed when fitting a newer TFT instrument cluster (DIM) into older P3-platform cars. Without these terminals, cars up to MY2013 cannot have the required additional wiring connected into the white DIM connector.
What they're for:
During a TFT retrofit (upgrading the older DIM to a newer 2014–2017 TFT unit), cars up to MY2013 need 2 new wires added to the white DIM connector — at positions 7 and 8. These genuine Volvo terminals click securely into the connector body for a reliable, permanent connection (unlike used terminals salvaged from a scrapped connector).
How they're used (per our TFT Retrofit guide):
- Terminals are fitted into positions 7 and 8 of the white DIM connector
- The other end is connected with a twisted pair of wires to the OBD connector: DIM pin 7 ↔ OBD pin 6, DIM pin 8 ↔ OBD pin 14
- Connections should be made with quality 3M UB2A Scotchloks (avoid cheap alternatives) or soldered
Technical specifications:
- Genuine Volvo part number: 30656697
- Type: flat terminals, female (2 pcs needed per retrofit)
- Condition: new, genuine part
Fits models: Volvo S60/V60, XC60, S80 II, V70/XC70 III (P3 platform), model years up to 2013 (MY14+ cars already have this wiring from the factory, so terminals aren't needed).
Pair this with VDASH to complete the new TFT cluster configuration — see our TFT Retrofit guide.
