VDASH Guide
VDASH Basics
How to download VDASH, prepare the required hardware, connect your Volvo, and log in for the first time.
Overview
VDASH is a Windows software tool for Volvo diagnostics, configuration, service functions, software operations, and selected module-related procedures. It connects to the vehicle through the OBD-II socket using a compatible diagnostic interface.
Before using VDASH for the first time, prepare your computer, internet connection, diagnostic hardware, D5T5 account, and vehicle power supply.
What You Need
- A computer with Windows 7, 8, 10, or 11
- Internet access
- A compatible diagnostic interface, such as Volvo DiCE, SUPER J2534, or another supported J2534 device
- A 12V battery charger connected to the vehicle (strongly recommended)
- A laptop charger (recommended if the laptop battery is weak)
- A D5T5 account
Recommendation: Use Windows 10 or newer whenever possible.
Download and Install VDASH
- Download the VDASH installer or the portable version.
- Run the installer and follow the installation steps.
- Once complete, VDASH is successfully installed.
Direct download:
• Download VDASH installer (recommended)
• Download portable VDASH
How to Download VDASH
SUPER J2534 Interface and Drivers
SUPER J2534 is the recommended general Volvo DiCE replacement for VDASH use. It is suitable for diagnostics, software operations, and selected decoding operations.
You can either purchase SUPER J2534 in our e-shop or rent SUPER J2534 in our e-shop.
SUPER J2534 drivers:
Register and Log In
- Create an account directly in VDASH or on the D5T5 website.
- Open VDASH on your computer.
- Allow firewall rule creation if Windows asks for permission.
- Enter your e-mail or nickname.
- Enter your password and log in.
How to Register and Log In
Connect Your Volvo to VDASH
- Connect a 12V battery charger to the vehicle's starter battery and check correct polarity.
- Plug the diagnostic interface into the OBD-II socket.
- Connect the diagnostic interface to your computer by USB.
- Turn the ignition to position II:
- Mechanical key: turn the key just before the engine start position.
- Start button: hold the button for approx. 5 seconds without pressing the brake or clutch.
- With VDASH open, wait until VDASH detects the vehicle.
- Click "Connect".
- VDASH will start scanning the vehicle and loading the available modules.
Important: Keep the vehicle and laptop powered during diagnostics, software operations, PIN decoding, and programming. Do not disconnect the diagnostic interface while an operation is running.
