In stock
BigPack Volvo C30 S40 V50 C70 Turbo 04-13, Black hoses
Our code: BIG-V50-S
This BigPack includes the do88 performance intercooler and a complete intercooler pipe kit. It is designed for those with high power goals who want to upgrade to the absolute best. Replacing the intercooler alone is a major improvement, but combined with the do88 pressure pipes the gain is enormous.
Key advantages of the do88 BigPack over OEM intercooler and pipes:
  • Core volume: 9,677 cm³ (vs. 3,672 cm³), 163% larger!
  • Air flow at 0.15 bar / 2.18 psi pressure drop: 275 CFM (vs. 244 CFM), 13% higher!
  • Post-intercooler air temperature at the same conditions: 38°C (vs. 69°C), 31°C lower!
  • Fits all vehicles listed below!
A 31°C reduction in post-intercooler air temperature and a 13% increase in airflow is a remarkable improvement. The BigPack replaces everything between the turbo outlet and the throttle body, dramatically improving airflow and cooling performance compared to the original system.
The intercooler is an all-aluminium construction with CAD-designed, flow-optimized cast end tanks and an optimized core design for maximum cooling efficiency and minimum pressure drop. The pressure pipes are manufactured from 2.5" mandrel-bent seamless aluminium tubing. The silicone hoses are custom-made with four layers of polyester/aramid reinforcement — capable of withstanding high temperatures and pressures.
Upgrading the intercooler and pressure pipes makes sense even on a standard, non-tuned car — you will feel the difference immediately. The full performance benefit is realized particularly after an ECU tune.
The kit comes with all hardware necessary for installation.
Installation instructions » Instructions
BigPack contents:
  1. Performance intercooler
  2. Intercooler installation accessories
  3. One 2.5" pressure pipe
  4. Pressure pipe installation accessories
  5. Three silicone hoses
  6. Six hose clamps
Compatibility
Volvo C30 – 2006–2013 | Engine: T5 turbo (B5254T3, B5254T7)
Volvo C70 – 2006–2013 | Engine: T5 turbo (B5254T3, B5254T7)
Volvo S40 – 2004–2012 | Engine: T5 turbo (B5254T3, B5254T7) |  Does not fit four-wheel drive models
Volvo V50 – 2004–2012 | Engine: T5 turbo (B5254T3, B5254T7) |  Does not fit four-wheel drive models
OE References
31319262 · 8649763 · 8649767 · 8649765 · 30794304
Important Notice – Return Policy
This product falls under the category of performance and custom parts. Due to the specific nature and intended use of such products, the standard 14-day right of withdrawal does not apply. By purchasing this product, the customer acknowledges and agrees to this condition.
In the event of a warranty claim due to a manufacturing defect, we proceed in accordance with applicable legal regulations.
€804.48
€664.86 without 21% VAT
Warehouse
Nový Bor - CZ 2 pcs
Quantity
