In stock
Volvo S60 R V70 R S80 Manual 99-08 Radiator
Our code: Radiator_Man_do88
do88 Performance Radiator for Volvo S60 / V70 / S80 with Manual Gearbox (1999–2008)
This radiator was developed by do88 as a direct replacement for the original part, delivering real performance gains without the need for major modifications to the vehicle.
Key advantages of the do88 radiator over the OEM radiator
  • 25% larger cooling area compared to the original part!
  • Fits all vehicles listed below!
Key features
  • Drop-in installation, no modifications required. Clamps and bushings are reused from the original radiator.
  • High-efficiency core with 6.5mm fin height in a multi-louvered design.
  • Dual core design, 2-row, 40mm thick core.
This radiator is designed to deliver the best cooling efficiency even under demanding conditions. Manufactured exclusively from aluminium with continuous welds, it guarantees reliability and durability exactly when you need it most. The increased cooling area improves heat dissipation and reduces coolant temperature. The radiator is perfectly optimized for the available space in the engine bay, allowing for easy drop-in fitment. The all-metal construction eliminates the common issue of cracking plastic tanks found in the OEM unit.
Installation instructions » Instructions
Important notice: If you plan to install this radiator together with an intercooler other than do88 or OEM, please read step 24 in the installation instructions before placing your order.
Compatibility
Volvo S60 / S60 R – 2001–2008 | all engines | manual gearbox only
Volvo V70 / V70 R – 2001–2007 | all engines | manual gearbox only
Volvo S80 – 1999–2006 | all engines | manual gearbox only
Volvo XC70 – 2001–2007 | all engines | manual gearbox only
OE References (replaced parts)
31319056 · 31319062
Important Notice – Return Policy
This product falls under the category of performance and custom parts. Due to the specific nature and intended use of such products, the standard 14-day right of withdrawal does not apply. By purchasing this product, the customer acknowledges and agrees to this condition.
In the event of a warranty claim due to a manufacturing defect, we proceed in accordance with applicable legal regulations.
€515.93
€426.39 without 21% VAT
Warehouse
Nový Bor - CZ 1 pcs
Quantity
