VDASH Guide
Volvo PIN Codes Explained
Every Volvo since 1998 has two basic security levels: CEM and ECM. In newer vehicles, additional units like IEM, VGM, and others are integrated into this security system.
Overview
Volvo Security Memory Overview
The content of the programming memory in these units is essentially divided into two parts:
1. Programming Memory Protected by a PIN Code
The first programming part of the memory requires a unique PIN code to overwrite the software. This dictates how the unit behaves, for example the software version and configuration table in the CEM unit or, typically from 2008 onwards, the engine maps in the ECM unit.
2. Immobilizer Memory Protected by an IMMO PIN
The second programming part is memory requiring an IMMO PIN. This protects the EEPROM memory where synchronization codes are stored, which are typically essential for starting the vehicle.
It involves synchronizing a unique number between the central CEM unit and the ECM engine unit. If this code does not match, the vehicle will not start. In newer vehicles, additional units like the BCM brake unit, the SCL steering wheel lock, ignition keys, remote controls, and audio system are integrated into the synchronization system.
For most vehicles, the CEM/ECM PIN and CEM IMMO can be decoded using VDASH or VDD. This allows most vehicle operations to be performed without the need to remove the unit and physically connect it to a specific programmer.
Units that cannot be decoded via OBD can usually be decoded by removing and reading the unit, known as on the bench.
Alternative method: Another way to obtain the PIN and IMMO code is to upload software from the official VIDA diagnostic and capture the programming key during the upload. However, Volvo considers this method illegal and in direct violation of the Volvo VIDA licensing agreement.
If you have obtained the PIN or IMMO code for your Volvo in any way, you can enter the code into the VDASH system at this address: https://d5t5.com/pin
What PIN Codes Are
What Are Volvo PIN Codes?
Volvo PIN codes are security credentials embedded in vehicle control modules. They are required to:
Modify software
Change configuration
Pair components
Pair immobilizers
They exist because modern Volvos use anti-theft and anti-tampering protection to prevent:
  • Unauthorized software changes
  • Swapping ECUs between cars
  • Cloning modules via OBD
This is why many Volvo modules cannot simply be reused from another vehicle without reprogramming.
CEM: Central Electronic Module
  • Acts as the vehicle’s central controller
  • Handles configuration, features, and communication
ECM: Engine Control Module
  • Controls engine behavior
  • Stores engine maps and performance logic
In newer cars, additional modules are integrated:
  • BCM: brakes
  • SCL: steering lock
  • Keys and remotes
  • Audio system, via MOST network
PIN Types
Types of Volvo PIN Codes
CEM PIN
Purpose: Vehicle configuration and software updates.
Used for:
  • Activating navigation
  • Changing market settings, such as US ↔ EU
  • Removing speed limiter
  • Uploading a newer software version
This is the most commonly used PIN.
Decoding via VDASH:
  • P1 GGD, typically 2011+
  • P2 GGD, XC90 3.2 / 4.4 V8 / 147kW and 120kW D5 MY13+
  • P3
  • SPA 2015-2018
  • SPA 2021+, if we know the VGM PIN
Decoding via VDD:
  • P1
  • P2 from MY2005+
  • P3
  • SPA 2015-2018
CEM IMMO PIN
Purpose: Immobilizer and security pairing.
Used for:
  • Adding new keys
  • Syncing CEM ↔ ECM
  • Pairing steering lock, SCL
  • Pairing security modules
  • Pairing audio components
Critical for vehicle start authorization.
Decoding via VDASH:
  • P1
  • P2 except XC90 3.2 / 4.4 V8 / 147kW and 120kW D5 MY13+
  • P3
ECM PIN
Purpose: Engine software modification.
Used for:
  • Performance tuning
  • Disabling systems, such as EGR or DPF
  • Removing fault codes
Decoding:
  • Not needed for P1 until approximately MY2011
  • Not needed for P2
  • Via OBD on P3 DENSO units
  • SPA 2015-2018 using UCBP and VDASH
ECM IMMO PIN
Purpose: Engine immobilizer synchronization.
Used for:
  • Syncing ECM with CEM
  • Pairing brake module, BCM
Ensures the engine ECU is trusted by the car.
Decoding via VDASH:
  • P1, 1.6D 80kW / 2.4D 5-cylinder
  • P3 DENSO VEA
  • SPA 2015-2018
VGM PIN: Newer Vehicles
Purpose: Full-vehicle diagnostics and control.
Applies to: Cars with Android-based systems, also known as iCUP.
Used for:
  • Clearing diagnostic codes across the entire vehicle
  • Advanced operations
Important:
  • Cannot be decoded via OBD
  • Must be obtained via official Volvo systems
How to Obtain PIN Codes
How to Obtain Volvo PIN Codes
Method 1: OBD Decoding
This is the most common method.
Using tools like:
Advantages:
  • No need to remove modules
  • Works on many platforms
For further instructions, follow our article on how to obtain the CEM / ECM PIN from your Volvo.
Method 2: Bench Reading
  • Remove ECU/CEM
  • Read memory directly with a programmer
Used when:
  • OBD decoding is not possible
We offer this option for some P1 and P2 CEMs and P3 ECMs, EDC17CP22 / EDC17CP48.
Method 3: Intercepting VIDA Programming
  • Capture PIN during official software upload
Important: This method is considered illegal by Volvo because it violates licensing agreements.
Important Notes
Important Notes Before Decoding
Decoding with VDASH does not require any credit. You only need an account and to connect your Volvo to VDASH with a DiCE or Generic J2534, such as SUPER J2534 from our e-shop.
CEM PIN, ECM PIN, IMMO code, and other codes in Volvo cars are why some units cannot be easily cloned via OBD and cannot be used from another vehicle without modifications.
If the option to decode a PIN is greyed out in VDASH, it means that the specific PIN cannot be decoded.
Final Takeaway
Volvo PIN codes protect software, immobilizer synchronization, and module pairing
CEM PIN, ECM PIN, IMMO codes, and newer security codes determine what can be changed, paired, decoded, or reused in a Volvo. In many cases, VDASH or VDD can decode the required code through OBD, but some modules require bench reading or special access, like the VGM PIN.
volvo pin codes volvo cem pin volvo ecm pin programming codes immo code vgm pin pin code decoding cem pin ecm pin cem immo ecm immo
