VDASH Guide
HU850 Retrofit
Important checks before replacing HU650 with HU850 audio on a P2.
HU850 retrofit requirements
Before installing HU850 audio
When retrofitting HU850 audio in place of the original HU650, the radio itself is only one part of the system. Before replacing the head unit, make sure the rest of the audio setup is already prepared and working correctly.
- The audio amplifier under the passenger seat must be installed.
- There must also be 2 additional cables leading from the amplifier to the HU850.
- The amplifier must have a proper 12V power supply.
- Before fitting the HU850, test the amplifier setup with the original HU650 first. If the audio works with HU650, only then continue with the HU850 installation.
- Make sure the HU850 unit itself is fully functional. This radio is known for possible hardware failures, where the sound may drop out and the unit then requires refurbishment.
Configuration note:
There is no actual need for CEM configuration for this retrofit. If the amplifier, wiring, power supply, and HU850 unit are all correct, the HU850 will play normally. The only side effect should be one extra DTC stored in the vehicle.
