SRS-CFFF
Very common fault for Volvo P1 cars (C30 / S40II / V50 / C70). The official way to fix this error is to replace the SRS unit by a Volvo dealer for approximately €800.
VDASH can fix this error via OBD without any harm to the airbag system (everything will work as if you replaced the ECU).
This fault usually occurs when the car battery is low or damaged, or if the charging system has some fault (check alternator and contacts).
How to fix the SRS-CFFF fault?
- Connect your car to VDASH
- On the diagnostic screen, select the button "SRS-CFFF Fix"
- Load the software
The whole process takes approximately 5 minutes, and you don't need to disassemble anything!
