In stock
Volvo S60 V70 XC70 S80 Turbo 00-09 Intercooler
Our code: ICM-160
do88 Performance Intercooler for Volvo V70 / S60 / S80
This intercooler was developed by do88 as a direct replacement for the original part, delivering real performance gains without the need for major modifications to the vehicle.
Key advantages of the do88 performance intercooler over the OEM intercooler:
  • Core volume: 13,068 cm³ (vs. 8,659 cm³), 51% larger!
  • Air flow at 0.15 bar / 2.18 psi pressure drop: 319 CFM (vs. 272 CFM), 17% higher!
  • Post-intercooler air temperature at the same conditions: 30°C (vs. 54°C), 24°C lower!
The intercooler features an all-aluminium construction with CAD-designed, flow-optimized cast end tanks and an optimized core design to achieve maximum cooling efficiency combined with minimum pressure drop.
The OEM intercooler was designed for the power level the car left the factory with. Under increased power output or demanding driving conditions, its capacity may prove insufficient. The full performance benefit of the do88 intercooler is realized particularly after an ECU tune. Additionally, the original intercooler is fitted with plastic end tanks that struggle to cope with higher boost pressures — the do88 intercooler eliminates this concern with its fully aluminium construction.
The intercooler comes with all hardware necessary for installation. It fits all Volvo S60 / V70 / XC70 / S80 turbocharged models, with or without a sensor on the intercooler outlet — a mounting plate and a block-off plate for sensor-less applications are both included in the package.
Installation instructions » Instructions
Compatibility
Volvo S60 – 2001–2009 | Engines: R / T5 / 2.4T / 2.5T (petrol, turbo), D5 / 2.4D (diesel)
Volvo V70 – 2001–2007 | Engines: R / T5 / 2.4T / 2.5T (petrol, turbo), D5 / 2.4D (diesel)
Volvo XC70 – 2002–2007 | Engines: 2.4T / 2.5T (petrol, turbo), D5 / 2.4D (diesel)
Volvo S80 – 1999–2006 | Engines: 2.4T / 2.5T (petrol, turbo), D5 / 2.4D (diesel)
OE References
8649471 · 8671694 · 8683169
Important Notice – Return Policy
This product falls under the category of performance and custom parts. Due to the specific nature and intended use of such products, the standard 14-day right of withdrawal does not apply. By purchasing this product, the customer acknowledges and agrees to this condition.
In the event of a warranty claim due to a manufacturing defect, we proceed in accordance with applicable legal regulations.
€681.05
€562.85 without 21% VAT
Warehouse
Nový Bor - CZ 1 pcs
Quantity
