NAREX AS 37-Li HYBRO Cordless Hybrid Screwdriver
Our code: Screwdriver1Narex AS 37-Li HYBRO Cordless Hybrid Screwdriver
The world's first cordless screwdriver combining the performance of a conventional manual screwdriver with the power of a battery-driven tool. This unique hybrid design bridges the gap between cordless and manual use — lightweight and precise for delicate tasks, fully energized for demanding projects.
The ergonomically refined axial design allows easy application in tight and hard-to-reach spaces. A reliable motor and robust all-metal gearbox deliver high tightening torque and long service life. Automatic spindle lock enables instant switching to manual screwdriving mode.
The lightest Li-Ion cell on the market ensures the longest stand-by response time available. Features a built-in fast charger with electronic monitoring and color LED indicator, plus a USB-C charging port for convenient charging from standard mobile devices. Automatic LED work light illuminates dark workspaces, and a quick-release chuck system supports a wide range of accessories.
In the box: USB-C charging cable, 75 mm bit PH0, 75 mm bit PH1, 75 mm bit H4, double-ended 110 mm bit PH2/F5.5, blister packaging
| Parameter | Value |
| Voltage | 3.6 V |
| No-load speed | 280 rpm |
| Max. screw Ø in wood | 5 mm (Cordless) / 3 mm (Manual) |
| Max. torque | 4 Nm (Cordless) / 10 Nm (Manual) |
| Application range | max. M8 |
| Chuck type | E6.3 |
| Charging time | approx. 45 min |
| Weight | 0.162 kg |
€34.94
€28.88 without 21% VAT
| Warehouse | |
| Nový Bor - CZ | 5 pcs |
