VEA ECM unlock adaptor - UCBP
Our code: 33556Tool for unlocking VEA Engine Control Module - with original ECM connector!
in future compatible with other units
currenty compatible VEA (P3 and SPA) engines B4204x and D4204x between 2014 - 2018
This tool works only with DiCE or compatible J2534 device!
We recommend the genuine DiCE! With the Chinese clone DiCE it sometimes does NOT work or may be unstable!
for more info please follow the WiKi: https://d5t5.com/article/how-unlock-and-tune-vea-with-vdash-ucbp
Supported VEA HW numbers:
- 31312484
- 31361735
- 31459244
- 31459298
- 31312486
- 31452623
- 31452230
- 31459914
- 31452233
- 31459913
Test your self, if you are Color Blind or not and let us know - we send you special version with described wires
https://www.colorlitelens.com/color-blindness-test.html
We recommend to buy the external power cables: https://d5t5.com/eshop/detail/134/external-power-cables-for-ucbp
You can also build your own according our tutorial (no support and no warranty!) - https://oshpark.com/shared_projects/LnEOy7nr
€143.99
€119.00 without 21% VAT
