How to Fix SRS-CFFF with VDASH
Repair a common Volvo P1 SRS fault through OBD without replacing the SRS control unit.
Fault Overview
What Is the SRS-CFFF Fault?
The SRS-CFFF fault is a well-known issue on Volvo P1 platform vehicles.
It commonly appears on the Volvo C30, S40II, V50, and C70II.
The official repair method is usually to replace the complete SRS control unit at a Volvo dealer. This repair can cost approximately €800, depending on the vehicle and dealer pricing.
VDASH Solution
Fix the Fault Directly Through OBD
With VDASH, the SRS-CFFF fault can be repaired directly through the vehicle’s OBD port. There is no need to remove the SRS unit, disassemble the interior, or replace any hardware.
After the VDASH fix, the SRS system works as if the SRS unit had been replaced.
Affected Vehicles
Commonly Affected Volvo P1 Models
This repair applies to Volvo P1 vehicles where the SRS-CFFF fault is present.
Volvo C30
Volvo S40 — 2nd generation
Volvo V50
Volvo C70 — 2nd generation
Common Causes
Why Does SRS-CFFF Appear?
The SRS-CFFF fault is often caused by voltage-related problems or incorrect startup conditions. Before performing the repair, it is recommended to check the battery and charging system so the issue does not return.
Battery Condition
A weak, low, or damaged battery can trigger the fault, especially after short trips during winter.
Charging System Problems
Alternator faults, poor electrical contacts, or unstable charging voltage can contribute to the issue.
Starting Too Quickly
Starting the vehicle before the warning gong has finished can also trigger the SRS-CFFF fault.
Repair Procedure
The repair is performed completely through VDASH. No mechanical work or disassembly is required.
Step 1
Connect the vehicle to VDASH via DiCE, generic J2534, or the SUPER J2534, which you can purchase from our e-shop.
Step 2
Open the diagnostic screen and select the “SRS-CFFF Fix” button.
Step 3
Load the software and allow VDASH to complete the repair.
Price & Time
Repair Cost and Duration
Price
€120 incl. VAT (21%)
Estimated Time
Approximately 5 minutes
Final takeaway
Repair SRS-CFFF Without Disassembly
The entire SRS-CFFF repair process takes approximately 5 minutes. No parts need to be removed, no SRS unit replacement is required, and the fix can be completed directly in VDASH through OBD.
SRS-CFFFfix VolvoP1Solution VDASHmagic AirbagSafety EasyErrorRepair VolvoCFFF SRS-CFFF
