Rebuild kit for the front brakes in Volvo S/V60s with the original diameter 300-mm.
Parts used from V60 D6 with a diameter 336-mm.
Part numbers needed for complete rebuild:
- 2 pcs belt holder: 8603758
- Brake calliper PP: 36000375
- Brake calliper LP: 36000376
- 2 pcs brake tube: 31305088
- 2 pcs spring calliper: 30671593
- Metal covering disc PP: 30681690
- Metal covering disc LP: 30681691
- 2 pcs disc 336-mm for Volvo S/V60
- Pack of brake pads pro 336-mm for Volvo S/V60
Rims smaller than 17” cannot be used after this installation!
