PIN decoding for ECM - motor unit - chiptuning
EDC16C31 in platform 3 - 5-cyl diesel Euro4 engines
- if you need to decode this unit, use our contact form or contact our dealers from VDASH PRO or VDASH PRO VERIFIED.
- or send the ECU to us https://d5t5.com/article/contacts-d5t5-s-r-o
EDC17CP22, EDC17CP48, EDC17CP68, MED17 - 5-cyl diesel/petrol engines
- if you have this unit to decode, use our contact form or contact our dealers from VDASH PRO or VDASH PRO VERIFIED.
Denso unit - 3.2, V8, T6 engines
PIN decoding is possible via VDASH
Steps:
- Connect the vehicle to the PC by using Volvo DiCE, start VDASH - internet connection is required. Computer must be connected to the charger and all savings modes must be switched off.
- Connect the vehicle to a charger with a capability of 12A at least.
- Log in to VDASH and detect the vehicle. The DECODE ECM PIN option appears on the home page.
VEA Denso unit - latest 4-cyl diesel/petrol engines D42xx a B42xx
Early VEA ECM units can be unlocked using: https://d5t5.com/article/how-unlock-and-tune-vea-with-vdash-ucbp
CEM - central module - PIN decoding for changing vehicle’s configuration
PIN decoding can be done via VDASH - connect the vehicle to the PC using Volvo DiCE, start VDASH - internet connection is required. Connect the vehicle to a charger with a capability of 12A at least and ensure connecting the computer charger and all savings modes must be switched off. If the battery charger fails or is not strong enough, VDASH will automatically interrupt decoding if the battery voltage drops (or is equal to) below 11 V.
Log in to VDASH and detect the vehicle. The DECODE CEM PIN option appears on the home page. Decoding can be interrupted at any time and resumed later.
