Volvo zkratky
2 VALVE
2 valves/cylinder
2VVT
Double variable valve timing
2WD
Two-wheel drive
4 VALVE
4 valves/cylinder
4C
Continuously Controlled Chassis Concept
4CYL
4-cylinder engine
4DRS
4 door car
5CYL
5-cylinder engine
5DRS
5 door car
6CYL
6-cylinder engine
A
Ampere
A/C
Air Conditioning
ABL
Active BI-xenon lights
ABS
Anti-lock brakes
AC
Alternating Current
ACC
Automatic Climate Control
ACCM
Air Conditioning Control Module
ACEA
Association des Constructeurs Européens d'Automobiles
ACM
Alternator Control Module
ACU
Accessory Connectivity Unit
ADM
Additive Dosing Module
AEM
Accessory Electronic Module
AFM
AM/FM Tuner Module
AFS
Advanced Front Light System
AGM
Active Grille shutter Module
Ah
Ampere hours
AHB
Active High Beam
AHCM
Additional Heater Control Module
ALM
Ambience Lights Module
ALTER
Alternative
AM
Amplitude Modulation
AMP
Amplifier
ANC
Active Noise Control
AOC
Active On-demand Coupling
APMS
Airborne Particulate Matter Sensor
APN
Access Point Name
AQS
Air Quality Sensor
ASM
Air Suspension Module
AT
Automatic transmission
ATCM
All Terrain Control Module
ATDS
After Top Dead Center
ATM
Control module antenna (Antenna Module)
AUD
Control module audio (Audio Module)
AUM
AUTO.TRANS
AUU
Accessory USB Unit
AUX
Auxiliary equipment input
AWD
All-wheel drive
AYC
Active Yaw Control Sensor
BAM
Bluetooth Access Module
BBS
Battery Backed Siren
BCM
Brake Control Module
BCU
Battery Climate Unit
BDM
Battery Disconnect Module
BECM
Battery Energy Control Module
BEV
Battery Electric Vehicle
BLIS
Blind Spot Information System
BMM
Battery Management Module
BMS
Battery Monitoring Sensor
BPM
Bluetooth Phone Module
BPS
Brake Pressure Support
BSC
Body Sensor Cluster
BTDC
Before Top Dead Center
C
Celsius
CADS
Collision Avoidance Driver Support
CAN
Controller Area Network
CARB
Carburetor engine
CC
Cruise Control
CCA
Cold Cranking Amperes
CCC
Closed Coupled Catalyst
CCM
Climate Control Module
CCOT
Cycling Clutch Orifice Tube system
CD
Compact disc
CDM
Central Display Module
CEM
Central Electronic Module
CFCM
Cooling Fan Control Module
CFM
Climate Fan Module
CH TYPE
Chassis type
CHMSL
Extra brake light
CJB
Coupé Junction Box
CLS
Central locking system
cm
Centimeter
CMAP
Compressor Manifold Air Pressure
CMS
Catalyst Monitoring Sensor
CNG
Compressed natural gas
CO
Carbon Oxide
COAX
Coaxial cable
CODE
Code (upholstery code, color code)
COMBU
Heater can be combined with air conditioning
COMPL
Complete
CPM
Control module auxiliary heater (Combustion Preheater Module)
CPSR
Charge Power Sustain Relay
CRB
Central Relay Box
CRM
Control module convertible roof (Convertible Roof Module)
CSB
Connected Service Booking
CSC
Customer Service Center
CSD
Center Stack Display
CSM
Center Stack Module
CSPEAK
Centrally-mounted speaker
CTA
Cross Traffic Alert
CVBS
Composite Video Baseband Signal
CVC
Complete Vehicle Control
CVM
Closing Velocity Module
CVT
Continuous, variable transmission
CVVT
Continuous Variable Valve Timing
CWP
Coolant Water Pump
CYL
Cylinder
CZIP
Clean Zone Interior Package
D2
Volvo Diagnostics II
DABM
Digital Audio Broadcast Module
DAC
Driver Alert Control
DAS
Driver Alert System
DC
Direct Current
DCC
DisConnect Clutch
DCDC
DC to DC converter
DCM
Distance Control Module
DCP
Diesel Common rail Pump
DDM
Control module driver door (Driver Door Module)
DDRL
Dedicated Daytime Running Lights
DEF
Defroster Control Module
DEM
Control module four-wheel drive (Differential Electronic Module)
DFV
Dual Flow Valve
DiCE
Diagnostic Communication Equipment
DIM
Combination instrument (Driver Information Module)
DLC
Diamond Like Carbon
DMF
Double Mass Flywheel
DMM
Control module damper motor (Damper Motor Module)
DMS
Dealer Management System
DMTL
Diagnostic Module Tank Leakage
DPF
Diesel particle filter
DRL
Daylight running lights
DSA
Anti-spin system
DSL
Diesel
DSR
Driver Steering Recommendation
DSTC
Dynamic Stability Control System
DTC
Diagnostic Trouble Code
DVB-T
Digital Video Broadcast Terrestrial
DVD
Digital Versatile Disc
EA
Emergency Alarm
EBA
Emergency Brake Assist
EBD
Electronic Brake force Distribution
EBL
Emergency Brake Light
ECC
Electronic Climate Control
ECCM
Electric Charge Air Compressor Module
ECDS
Engine Cooler Detection Sensor
ECM
Engine Control Module
ECPS
Electrically Controlled Power Steering
ECU
Electronic Control Unit
EGR
Exhaust Gas Recirculation
EGTS
Exhaust Gas Temperature Sensor
EHPAS
Electro Hydraulic Power Assisted Steering
EJB
Engine Junction Box
EL-A/C
Electric A/C compressor
EMAP
Exhaust Manifold Absolute Pressure
EMOP
Electro Magnetic Oil Pump
EOE
Engine Order Enhancement
EOP
Electrical Operated Pump
EOR
Engine Order Reduction
EPAS
Electric Power Assisted Steering
EPB
Electric Parking Brake
EPS
Power steering
ERAD
Electric Rear Axle Drive
ERS
Engine Remote Start
ESC
Electronic Stability Control
ESM
Exterior Sound Module
ETA
Electronic Throttle Actuator
ETC
Electronic Temperature Control
ETM
Control module throttle damper (Electronic Throttle Module)
EVAP
Evaporative emission system
EXC
Excluding
EXCH
Exchange
F.S.B.
Seatbelt without rollers
F.STAB
Front anti-roll bar
FACM
Fuel Additive Control Module
FBS
Fading Brake Support
FC _
Factory Code
FCM
Fan Control Module
FCW
Forward Collision Warning
FET
Field Effect Transistor
FI
Fuel injection
FI XXX
Function-ID
FLR
Forward Looking Radar
FM
Frequency Modulation
FOH
Fuel Operated Heater
FoPB
Foot operated Parking Brake
Four-C
FSM
Forward Sensing Module
FTM
Fuel Tank Module
FWD
Front Wheel Drive
gallon UK
1 gallon (UK) = 4.546 liters
gallon US
1 gallon (US) = 3.785 liters
GDI
Gasoline Direct Injection
GDL
Gas Discharge Lamp
GDM
Graphic Display Module
GEN
Generator
GFT
Getrag Ford Transmissions
GGD
Generic Global Diagnostic Specification
GPS
Global Positioning System
GPSS
Guaranteed Price Service System
GSM
Gear selector
h
Hour
H.L.WIPER
Headlamp wiper
HBS
Heart Beat Sensor
HC
Hydro Carbon
HCM
Headlamp Control Module
HCML
Headlamp Control Module Left
HCMR
Headlamp Control Module Right
HDC
Hill Descent Control
HEV
Hybrid Electric Vehicle
HLA
High Level Audio (with AUD)
HLDF
High Level Display Front
HLDR
High Level Display Rear
hp
Horsepower, 1 hp = 0.7355 kW
HS
High Speed
HS CAN
High Speed CAN
HUD
Head Up Display
HUS
Humidity Sensor
i-ART
Intelligent Accuracy Refinement Technology
I.DIA
Diameter, inner
IAM
Integrated Audio Module
IAU
Immobilizer Antenna Unit
IC
Integrated Circuit
ICM
Infotainment Control Module
ICP
Infotainment Control Panel
iCUP
Infotainment Connectivity Unit Program / Android infotainment
IDIS
Intelligent Driver Information System
IDM
Novell Identity Manager
IEM
Inverter ERAD Module
IGBT
Insulated Gate Bipolar Transistor
IGM
Inverter Generator Module
IHU
Integrated Head Unit
IKM
Ignition Key Module
ILM
Interior Light Module
IMS
Interior Motion Sensor
IN.BELT
Seatbelt with rollers
inch
1 inch = 2.54 cm
INCL
Including
INTERCOOLER
With intercooler
IR
Infra Red
IRRL
Interior Rear Roof Lamp
ISC
Infra Red
ISG
Inverter System Controller
ISM
Inclination Sensor Module
K-Line
Serial data communication
kHz
kilo Hertz
km
Kilometer
km/h
Kilometer per hour
KVM
Keyless Vehicle Module
kW
Kilowatt
l
Liter
LCM
Left Camera Module
LDM
Left Rear Door Module
LDW
Lane Departure Warning
LED
Light Emitting Diode
LG
Length
LH
Left
LHCU
Left Headlamp Control Unit
LHD
Left-hand drive
LHT
Left-hand traffic
LIN
Local Interconnect Network
LKA
Lane Keeping Aid
LLA
Low Level Audio (w/o AUD)
LNT
Lean NOx Trap
LOS
Limited Operational Strategy
LPG
Liquefied petroleum gas
LS
Low Speed
LSM
Light Switch Module
LVDS
Low-Voltage Differential Signaling
m
Meter
MAF
Manifold Air Flow
MAN.TRANS
Manual transmission
MAP
MARKED
Marked with
MC
Market Code
MCC
Manual Climate Control
MD
Mini Disk
MDP
MD Player
MHEV
Mild Hybrid Electric Vehicle
mm
Millimeter
MMM
Multi Media Module
MMS
Mass Movement Sensor module
mm²
Square millimeters
MOSFET
Metal Oxide Semiconductor Field Effect Transistor
MOST
Media Oriented System Transport
MP1
MD Player Module
MP2
CD Player Module
mph
Miles per hour, 1 mph = 1.6 km/h
MPM
Media Player Module
MPS
Modular Power Shift
MS
CAN Medium Speed CAN
MS CAN
Medium Speed CAN
MW
Mechanical windows
N
Newton
NCT
New Car Training
NEDC
New European Driving Cycle
NICA
Nominated person In Control of work Activity
Nm
Newton meter
NMOG
Non-Methane Organic Gases
NTC
Negative Temperature Coefficient
NTSC
National Television Standards Committee
NVM
Night Vision Module
O.DIA
Diameter, outer
O.S
Oversize
OBC
On board charger
OBC GW
OnBoard Charger GateWay
OCH
Over Head Console
OHB
Optimised Hydraulic Brakes
OPTIC
Fiber optics
ORS
Occupant Remote Sensor
OWS
Occupant Weight Sensor
PAC
Parking Assistance Camera
PACOS
Passenger Airbag Cut Off Switch
PAD
Passenger Airbag Deactivated
PAE
Passenger Airbag Engaged
PAM
Parking Assistance Module
PAP
Park Assist Pilot
PAS
Park Assist System
PBM
Parking Brake Module
PCC
Personal Car Communicator
PCS
Pieces
PCV
Pre-stroke Control Valve, diesel
PDI
Pre Delivery Inspection
PDM
Passenger Door Module
PEM
Pump Electronic Module
PFB
Pre Fuse Box
PFD
Panel & Floor Air Distribution Flap
PHEV
Plug-in Hybrid Electric Vehicle
PHM
Phone Module
PIE
Product Information Exchange, a Volvo Cars system
PiH
Plug in Hybrid
POI
Point Of Interest
POT
Power Operated Tailgate Module
PPM
Pedestrian Protection Module
PPS
Pedestrian Protection System
PRICE
A system that contains information about parts
PRV
Pressure Relief Valve
PS
Power Steering
PSCM
Power Steering Control Module
PSL
Power Seat Module, Left
PSM
Power Seat Module
PSR
Power Seat Module, Right
PST
Personal Service Technician
PT
PowerTrain
PTC
Positive Temperature Coefficient
PVD
Physical Vapor Deposition
PW
Power windows
PWM
Pulse Width Modulated
QB
Quality Bulletin
R.AX
Rear axle
R.R
Raised roof
R.STAB
Rear stabilizer
r/min
Revolutions per minute (rpm)
RA
Road Assistance
RAB
Ready Alert Brakes
RASS
Remote Audio Stack Switches
RATD
Radiator Anti-Theft Device
RATIO
Ratio
RBCM
Redundant Brake Control Module
RBDS
Radio Broadcast Data System
RBMS
Redundant Battery Monitoring Sensor
RCCM
Rear Climate Control Module
RCCP
Rear Climate Control Panel
RCM
Right Camera Module
RDAR
Remote Digital Audio Receiver
RDM
Right Rear Door Module
RDS
Radio Data System
RDU
Remote Door Unlock
REC
Recirculation Control Module
REM
Rear Electronic Module
REPL
Replaced by
ReSC
Regenerative Stability Control
RFR
Radio Frequency Receiver
RGB
Red/Green/Blue
RH
Right
RHCU
Right Headlamp Control Unit
RHD
Right-hand drive
RHS
Remote Heater Start
RHT
Right-hand traffic
RJB
Rear Junction Box
RKE
Remote Keyless Entry
RME
Raps Methyl Ester
RPDM
Rear Passenger Door Module
RRW
Run off road warning
RRX
Remote Receiver Module
RSC
Roll Stability Control
RSD
Reduced Stopping Distance
RSE
Rear Seat Entertainment
RSI
Road Sign Information
RSM
Rain Sensor Module
RTI
Road Traffic Information
RTV
Room Temperature Vulcanizing silicone
RULO EVAP
Continuously functioning evaporation system
RVI
Remote Vehicle Immobilizer
S.R
Sun roof
S.W
Software
SAC
Self Adjusting Clutch
SAS
Steering wheel angle sensor
SC
Stability Control
SCL
Steering Column Lock
SCM
Siren Control Module
SCMC
Seat Control Module C
SCU
Start Control
SDN
SRS Deployment Notification
SEE FIG
See position
SFI
Sequential multiport Fuel Injection
SHM
Seat Heating Module
SHML
Seat Heating Module Left
SHMR
Seat Heating Module Right
SIM
Subscriber Identity Module
SIPS
Side Impact Protection System
SMM
Stepper Motor Module
SMS
Short Message System
SoC
State of Charge
SODL
Side Object Detection control module Left
SODR
Side Object Detection control module Right
SoH
State of health
SPCL
Special version
SPMA
Seatbelt Pretensioner Module A
SPMB
Seatbelt Pretensioner Module B
SRM
Sun Roof Module
SRS
Supplementary Restraint System Module
SSB
Start Stop Box
SSM
Safe Stop Module
SSR
Solid State Relay
STC
Stability and Traction Control
STD
Standard version
STD.DIM
Standard dimension
SUB
Subwoofer
SUM
Suspension Module
SVT
Stolen Vehicle Tracking
SW
Software
SWM
Steering Wheel Module
SWSL
Steering Wheel Switches Left
SWSR
Steering Wheel Switches Right
TAS
Torque and Angle Sensor
TB
Tool Bulletin
TCH
Thermal Cup Holder
TCM
Transmission Control Module
TEM
Telematics Electronic Module
TFT
Thin Film Transistor
THK
Thickness
TIE
Technical Information Exchange, a Volvo Cars system
TIM
Timer
TIS
Technical Information Shop
TJ
Technical Journal
TMAP
Temperature Manifold Absolute Pressure
TMC
Traffic Message Channel
TMPL
Temperature Control Left
TMPR
Temperature Control Right
TN
Theft Notification
TRACS
Traction control system
TRANS
Transmission
TRM
Trailer Module
TST
Technical Support Tool
TVM
Television Module
TWC
Three way catalytic converter
TXV
Thermal Expansion Valve
UDD
Unauthorized Driver Detection
UEM
Upper Electronic Module
uF
micro Farad
UMD
Unauthorized Movement Detection
US
Undersize
USB
Universal Serial Bus
V
Volt
VAC EVAP
Vacuum-controlled return system fuel vapors (see EVAP)
VAT
Value Added Tax
VCM
Vehicle Communication Module
VCT2000
Vehicle Communication Tool 2000
VCU
Vehicle Computationn Unit
VDASH
Volvo Diagnostic software by D5T5.com
VDD
VDASH Diagnostic Dongle by D5T5.com
VDN
Variant Designation Number
VDS
Volvo Diagnostics and Software download
VEA
Volvo Engine Architecture
VED
Volvo Engine Diesel
VEP
Volvo Engine Petrol
VGA
Video Graphics Array
VGLA
Volvo Guard Alarm System
VGM
Vehicle Gateway Module
VIDA
Vehicle Information and Diagnostics for Aftersales
VIN
Vehicle Identification Number
VOC
Volvo on Call
VST
Volvo Standard Time
VSTG
Volvo Standard Time Guide
VVT
Variable valve timing
W
Watt
WAM
Wide Angle vision Module
W/O
Without
WBL
Warning By Location
WI
Width
WLAN
Wireless Local Area Network
WMA
Windows Media Audio
WMM
Wiper Motor Module
WPC
Wireless Phone Charger
WRG
Water-repellent glass
WSL
Web Single Login
μf
micro Farad
Ω
Ohm
VOLVO volvo abbreviations volvo shortcuts volvo zkratky zkratky
