Volvo P3 SENSUS Heated Steering Wheel Retrofit
How to retrofit a heated steering wheel on compatible Volvo P3 SENSUS cars using VDASH.
Heated steering wheel retrofit
Applicable vehicles
Applicable for:
MY 2012+ – S80II, V70III, XC60, XC70III
MY 2013+ – S60II, V60
What you need
- Heated steering wheel
- HSWM module (heating unit for the steering wheel) - 31343460
- SAS ring - 31343662
- SWM module - 31481775
- Heated steering wheel button for CCM
- 15A fuse
- VDASH and SUPER J2534 or Volvo DiCE cable
- Check if your car has a compatible CEM H, model year 2014+, with HSWM output. If your car is below MY 2014, then you need to replace the CEM with a MY2014 model.
HSWM location
Procedure
- Connect VDASH and decode the CEM PIN for your car.
- Replace all related parts - SWM, SAS, steering wheel, and add the HSWM module. All cables should already be prewired in the car. Install the button into the CCM module. If there is already a button for collision warning disable, simply replace this button - the function will be moved into the IHU menu after the configuration change. Install the 15A fuse into the CEM module.
- Connect VDASH and enable heated steering wheel in car configuration.
- Reconnect the car again with VDASH and wait for the SAS fixup to appear in VDASH according to the changed car configuration.
- Reload the SAS module with SAS fixup and clear all codes.
- Voila! All done and working!
