VEA unlock - tune - DENSO
2020-07-05
How to unlock Volvo VEA ECM with VDASH? Follow this tutorial! If you dont have UCBP and you want to tune your car, you can build your own UCBP - HERE or just buy ours from our e-shop - HERE Supported HW numbers: …
Volvo diesel injectors codes and engine variants
2024-03-15
Injector part numbers according the Volvo platform and engine code Volvo platforms recognition is here: VOLVO platforms Some of those injectors requires coding the IMA codes or the injector class. Both can be done with VDASH or VIDA. P3 only …
VDD Dongle
2018-11-26
VDD - VDASH DONGLE – remote diagnostics, function extender, etc... UPDATE: VDD officialy available NOW in our e-shop! VDD - Volvo function extender To find out what is supported in your car, enter the VIN and press Enter: VDASH Dongle (VDD) is…
SRS-CFFF / CFFF Fix
2019-09-30
SRS-CFFF Very common fault for Volvo P1 cars (C30 / S40II / V50 / C70). Official way how to fix this eeror is replace the SRS unit by Volvo dealer for approx 800,- Eur. VDASH can fix this error via OBD without any harm of airbag system (all will…
P2 MY 1998 - 2004 VDD - úprava CEM pro podporu commandu na vozech P2 MY2000 - MY 2003
2021-04-19
VDD bridge CEM relays To be able to turn on the independent heater, lock, unlock etc.... for Volvo P2 MY 1998 - 2004, you need to bridge the relay in the CEM which disconnects the OBD socket when the key is removed from the ignition.
VDD Application
2020-09-04
Vdash Dongle application Application for remote controling Volvo cars. Service monitoring, remote controled additional functions (like starting fuel heater, air condition, ..). Remote assistance in case there's something wrong with the car or…
How to appear on the MAP as a D5T5 dealer?
2020-06-22
If you wish to be visible as a dealer on the D5T5 map, all that it requires is you simply going to VDASH and change the settings to dealer. https://d5t5.com/dealers/ The map is updated once every 24 hours.
VOLVO platforms
2018-12-30
Volvo Platforms P80 – classic This is for the S70, V70, C70 models. Usually, their year of production ranges from 1997 to 2004. These models are easily identified by the dashboard, which looks like the following photo: P1 – Platform 1 This is…
VDD Dongle - Fuel Heater doesn’t start when command “Heater Start” sent
2021-02-03
VDD Dongle - additional heater will not turn on after “Turn additional heater on” has been clicked on in the D5T5 VDD mobile app - Check all Diagnostic Trouble Codes (DTCs) related to additional heater on the Service page in the VDD…
Volvo abbreviations - zkratky
2022-11-17
Volvo abbreviations ABS Anti-lock Brake System modulate ABL Active Bending Light AC Alternating Current A/C Air Conditioning ACC Adaptive Cruise Control ACCM Air Conditioning Control Module ACM Alternator Control Module ADM Additive Dosing Module…
Volvo P2 keys and remotes explained
2024-03-13
Remote keys and ignition keys in Volvo P2 vehicles Volvo platforms are describedhere: VOLVO platforms The ignition key and the remote control in Volvo P2 platform vehicles are separate, and essentially, they do not relate to each other at all. The…
VDASH FLAT Tariffs
2023-10-09
Unlimited VDASH FLAT Config and VDASH FLAT Ultimate Plans In VDASH, two new tariff categories are now available for specific VIN (one vehicle), differing in the scope of services/software included in the tariff price. The FLAT tariff is generally…
Bluetooth modul BT PHONE P3GSM - Installation guide
2021-09-03
Installation Guide For the Bluetooth module BT PHONE P3GSMand audio extensions Note: Please read the whole Guide first before you start with the replacement. Caution: The Bluetooth module is an ESD sensitive board. Be careful after…
Známé chyby po nahrání optimalizace výkonu
2022-06-13
After performing engine optimization, the following errors are 95% likely to occur, which are only visible after loading any diagnostics. These are engine unit software checksum - ECM. The original checksum of the engine unit is stored in the…
ECM PIN decoding (applicable only for P3, SPA/CMA and P1 MY2012+)
2018-11-10
PIN decoding for ECM - motor unit - chiptuning EDC16C31 in platform 3 - 5-cyl diesel Euro4 engines - if you need to decode this unit, use our contact form or contact our dealers from VDASH PRO or VDASH PRO VERIFIED.- or send the ECU to us https:/…
Sensus - Navigation conversion US>EU MY2012-2014 (old sensus without globe key)
2020-06-23
If you want to convert your first generation Volvo Sensus (MY2012-2014 - without the globe key) navigation from USA market to Europe, then you need to load special conversion software via USB.Unfortunatelly, this service is not possible for now via…
EGR blanking plate - Euro3 D5 - D5244T/D5244T2
2019-11-04
If you load EGR OFF software into Euro3 engine (D5244T (120kW) or D5244T2 (96kW)) with VDASH, you must install EGR blanking plate according the pictures below: You can buy the blanking plate in our e-shop.
IHU Engineering Mode - change region settings P3
2020-01-17
After you have changed the region settings in car configuration (for example the USA market to EU), you also need to change the region settings in the entertainment system. If you do not do this the entire infotainment system will be extremely slow…
Pairing SCU / SCL unit
2023-10-05
Preconditions IMMO code must present - for P3 cars it is automatically decoded when CEM PIN is present or successfully decoded. The SCU / SCL unit must be new virgin (blue box), used SCU / SCL from another car can't be used. Procedure Ignition…
Volvo DiCE - update
2019-09-30
EN DiCE update VDASH works best with the latest Windows driver and the latest DiCE firmware. Both available for download: https://d5t5.com/sw/SetupDiCE.exe Update the DiCE firmware DiCE with SN 2xx.xxx to version 5.6.2 from: c:\Program Files\DiCE…
Boost pressure sensor clogged - diesel VEA and latest D5 5-cyl.
2020-01-17
If you have diesel car with 5-cylinder engine from 2012 or newer, or you have 4-cylinder VEA engine, then you need to clean the boost pressure sensor every 30-80.000-km. Otherwise your engine power will rapidly decrease and you can expect the engine…
Authorizing a new computer in VDASH
2019-10-15
If you've come across this notification in the VDASH system then most likely there has been a hardware change in your computer, or you have gotten a new computer and all spots for VDASH hardware are full. You can authorize your new computer via…
The CANALT wiring for VDD - SPA / CMA vehicle support
2021-11-15
The VDD Dongle CANALT wiring for SPA CMA cars The VDD dongle needs access to low speed CAN bus to enable to see status of locks, doors and windows, as well as to support Parking heater or Remote Engine start commands. To provide access to low speed…
XC90 LED Tail lights upgrade - MY2006+
2020-06-15
This is a quick tutorial on how to upgrade rear/tail lights for Volvo XC90s to LED lights, so you can go from this: to this: You will need: - LED lamps :)- your car must be MY2006 and above- the latest REM software- CEM configuration with VDASH: …
VDASH in virtual environment - VM / VMware / VirtualPC
2020-06-23
Running VDASH in a virtual environment is not allowed due to a very unstable between the USB connection and DiCE. We spent a lot of time running VDASH and car programming in a virtual environment and eventually decided to forbid using VDASH in said…
